To create an This command is available
on all Universal switches supported in this document. peer switch association structure, use
the following command:
create mlag peer peer_name
To delete a peer switch, use the following command:
delete mlag peer peer_name
To associate an MLAG peer structure with an MLAG peer
switch IP address, use the following command:
configure mlag peer peer_name
ipaddress
peer_ip_address {vr
VR}
To unconfigure the association, use the following
command:
unconfigure mlag peer peer_name
ipaddress
To configure the time interval between health check hello
packets exchanged between MLAG peer switches, use the following command:
interval
msec
To unconfigure the time interval setting and reset the
interval to the default of 1000 ms, use the following command:
interval
To bind a local port or LAG to an MLAG specified with an integer
identifier, use the following command:
enable mlag port port
peer
peer_name
id
identifier
To disable a local port or LAG from an MLAG, use the
following command:
disable mlag port port
To enable the current ports associated
with the given MLAG ID, use the following command:
enable ports [mlag-id
mlag_id]
To disable the current ports associated
disable ports [mlag-id
mlag_id]
To set a preference for having a fast convergence time or
conserving access lists, use the following command:
configure mlag ports convergence-control [conserve-access-lists | fast]
Executing the
refresh policy command with MLAG configuration
may result in health check hellos not reaching the CPU. To avoid MLAG peer connectivity
disruption, you can either execute the
disable
access-list refresh blackhole command or temporarily increase the peer hello
interval to a large value (for instance, 10000 ms) and reset it back once refresh policy
is complete.
To enable or disable MLAG linkup isolation, use the
following command:
configure mlag ports link-up-isolation [on | off]
To start orchestration mode, use the following command:
start orchestration
mlag
peer_name
To stop orchestration mode, use the following command:
stop {orchestration}
To configure MLAG reload delay timer, use the following command:
reload-delay
reload-delay
To enable MLAG reload delay timer, use the following command:
enable mlag port reload-delay
To disable MLAG reload delay timer, use the following command:
disable mlag port reload-delay
To view the configured MLAG reload delay timer setting, use the following
command:
show mlag ports {port_list}
To rename an existing MLAG peer, use the following command:
configure { mlag
peer } peer_name
name
new_peer_name
